Is my clutch going????
Usually its pretty obvious when a clutch is going but mine only seems to slip in first gear. If I just hold the throttle at 1/4 while taking off and keep it there the rev's will climb and the car won't really go any where, but if i step on the gas more it will take off fine. Also when my A/C is on in third gear from 3,500 to 4,000 rpms the intake goes wah wah wah until is passes over 4,000. I just got the car and don't beat on it at all but somethings not right. Any ideas?
[quote]ORIGINAL: mad_circle21
Usually its pretty obvious when a clutch is going but mine only seems to slip in first gear. If I just hold the throttle at 1/4 while taking off and keep it there the rev's will climb and the car won't really go any where. How many rpm is 1/4 throttle?
Sounds to me like your clutch is shot man...
well i tried the 30 mph into 5th and it didn't slip at all. I'm still not convinced though, today I tried to "see what it could do" and in between gears it seemed to slip a little. Maybe i'm just not used to the all wheel drive or something?
My car is an 00 a4 quattro with 69,000 miles. I have owned it for about a month so far, and am paranoid at every little thing that isn't perfect on it so i wanna fix everything I can to make it nice since i am so picky about it.
Dude, maybe the slave cylinder sticks. Try to release the clutch more at the take off, instead of keeping it in.
When I test drove A6 AWD, manul, it felt that I should have released clutch more. VS the FWD.
i def take it easy on the clutch or it clunks if i just dump the clutch like you would to chirp gears in a fwd car. I think the car is just that slow in 1st, lol, without boost and i'm not used to it. The only problem i really have then is when i get on it and after i shift from 2nd to 3rd it seems like it can't catch up with the shifting, and it slips.
ivanruiz817
Sep 16, 2011 02:38 AM
loves4
Feb 12, 2008 08:45 AM
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
