Is my clutch going????
Old Aug 8, 2006 | 01:08 AM
mad_circle21's Avatar
Default Is my clutch going????
Usually its pretty obvious when a clutch is going but mine only seems to slip in first gear. If I just hold the throttle at 1/4 while taking off and keep it there the rev's will climb and the car won't really go any where, but if i step on the gas more it will take off fine. Also when my A/C is on in third gear from 3,500 to 4,000 rpms the intake goes wah wah wah until is passes over 4,000. I just got the car and don't beat on it at all but somethings not right. Any ideas?
Old Aug 8, 2006 | 01:44 AM
Beer Mod's Avatar
Default RE: Is my clutch going????
[quote]ORIGINAL: mad_circle21
Usually its pretty obvious when a clutch is going but mine only seems to slip in first gear. If I just hold the throttle at 1/4 while taking off and keep it there the rev's will climb and the car won't really go any where. How many rpm is 1/4 throttle?
Sounds to me like your clutch is shot man...
Old Aug 8, 2006 | 01:56 AM
wood_e's Avatar
Get up to 30 and put it in 5th gear, then put on full throttle. If the revs jump its time for a new clutch.
Old Aug 10, 2006 | 11:44 PM
i'll try that, i hope its not. About how much does it cost to have the clutch done?
Old Aug 11, 2006 | 03:12 AM
luvin_the_rings's Avatar
alot
Old Aug 11, 2006 | 04:02 AM
Adam@mvp's Avatar
yea that sounds like your clutch is going out
how many miles do you have on the clutch
is it stock or aftermarket????
Old Aug 12, 2006 | 04:00 AM
well i tried the 30 mph into 5th and it didn't slip at all. I'm still not convinced though, today I tried to "see what it could do" and in between gears it seemed to slip a little. Maybe i'm just not used to the all wheel drive or something?
My car is an 00 a4 quattro with 69,000 miles. I have owned it for about a month so far, and am paranoid at every little thing that isn't perfect on it so i wanna fix everything I can to make it nice since i am so picky about it.
Old Aug 12, 2006 | 11:43 AM
kakarot's Avatar
Dude, maybe the slave cylinder sticks. Try to release the clutch more at the take off, instead of keeping it in.
When I test drove A6 AWD, manul, it felt that I should have released clutch more. VS the FWD.
Old Aug 13, 2006 | 06:15 PM
i def take it easy on the clutch or it clunks if i just dump the clutch like you would to chirp gears in a fwd car. I think the car is just that slow in 1st, lol, without boost and i'm not used to it. The only problem i really have then is when i get on it and after i shift from 2nd to 3rd it seems like it can't catch up with the shifting, and it slips.
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
