Need help with 2 CEL codes
Old Mar 18, 2007 | 11:15 PM
discontained's Avatar
Default Need help with 2 CEL codes
Hi i noticed my turbo was not spooling and my performance sucked, so i ran to buy a OBD II code reader. I found out 2 codes along with a CEL code..
[ol][*]P0102 - MAF or VAF a Circuit Low Input[*]P0171 - System Too Lean (Bank 1)
[/ol]Car is stock except a K&N Cone filter mod. she has abotu 106k on her and everything is fine except a ABS light. Any help would be grateful!
Old Mar 19, 2007 | 12:13 AM
david9999's Avatar
Default RE: Need help with 2 CEL codes
102 Mass flow sensor. Check the wiring and check to see that connections are tight and that there is no leak in the intake system. You might try to clean the MAF with some spray alcohol. Over oiling the K&N is said to kill your MAF.
171 Can be caused by MAF issue
Old Mar 19, 2007 | 12:26 AM
thanks, ill try that tomorrow and erase the codes.
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
