need help getting pointed in the right direction
Old Jan 26, 2006 | 05:41 AM
y2karnival's Avatar
Banned
Default need help getting pointed in the right direction
i bought an already giac chipped ecu for my 99 a4, and got the maf low cir input code and throttle position contr malfunction. ( i did the whole throttle adaption thing too)..well got it cleared and drove it for a day with just rough idling..on my way home from work tonight the cel came on again, and im assuming its the same codes..just need to know where i should look for problems with these codes, or should i just put the factory ecu back in and assume this chipped one doesnt work for me. i really liked the power gains though; even if i only got to feel em for a day.
Old Jan 26, 2006 | 05:51 AM
BadLuckAudi's Avatar
Default RE: need help getting pointed in the right direction
Did you make sure everything was exactly the same on your old ecu as far as numbers go?? Id try the throttle adaption thing again and drive it for a while see if it clears up........
Old Jan 26, 2006 | 02:50 PM
y2karnival's Avatar
Banned
the numbers are the same...and im trying the throttle adaption again...but i also noticed that at the top of the vacuum hose going into the intake manifold is starting to fray alittle bit....is that just a cover for the real hose underneath, or is that the actual hose cuz if so then maybe thats the probable its starting to leak through.
Old Jan 26, 2006 | 03:42 PM
Jeff's Avatar
Zombie Defense Force
i would go and check for leaks, and feel with your hand if u can feel a leak at the hose u were talking about
Old Jan 26, 2006 | 03:46 PM
black991.8tq's Avatar
du u have a boost gauge?????
Audi4me?
Jul 17, 2013 12:14 PM
Joshanlou
Sep 16, 2011 05:31 PM
teeebagTOM
Jul 25, 2009 08:59 PM
ouTTie914
Aug 22, 2007 11:58 PM
Jacek
Aug 2, 2005 12:05 AM
