New A4 is very loud
Old Nov 24, 2006 | 05:48 PM
  #21
ken sloat's Avatar
Default RE: New A4 is very loud
As someone has already stated, the method of injection should have something to do with the engine noise. Also, higher compression ratio will always create a different exhaust note, similar to the difference you might see from using a cam with a higher lift, or more aggressive pattern.
Anyways, the 2.0 runs fine. Peak torque is achieved at less than 2,000 RPM, and the car pulls hard right up to redline. The low end torque is great on the freeway, as I don't have to downshift to pass (accelerating from 70mph to 90 mph in 6th gear is fairly comfortable).
The higher compression ratio contributes greatly to the increased torque. Turbo lag is less of an issue with the engine does not rely to heavily on boost to make power. 10.5:1 CR is high for a boosted engine though, and I do wonder how this will affect the engine's ability to benefit from increased PSI without damage. the OEM turbo should be able to put out about 13 PSI. Without extensive cooling measures, I'm not sure that 93 octane pump gas would be enough to support that level of power without detonation. I'll let someone else try it before I do.
Then again, I could be completely wrong about all of this. I don't tinker with things other than pushrod V8's, and I'm not really sure how this knowledge translates to this type of engine
ORIGINAL: Amze
Thats interesting.... Why would the 2.0T's be so loud, 1.8T's run like a dream especially on the freeway. How are 2.0T's on the freeway?
Old Nov 24, 2006 | 06:14 PM
  #22
techbod's Avatar
is it really a fuel octane related problem?? I know 87 is the lowest crap you can use and will increase tappet/ lifter noise similar to that bioethanol crap which the computer is designed to compensate via the knock sensors so what type of noise are you on about but you loose 30% MPG with that crap
Old Nov 24, 2006 | 08:06 PM
  #23
18T's Avatar
18T
ORIGINAL: Amze
so far only the tips have been makin that noise. the manuals dont.
Old Nov 30, 2006 | 06:30 PM
  #24
mudpuppu_94's Avatar
not sure if this help or not but i was having a similar problem with my jeep. ended up slinging a rod out the block. never did figure out what was wrong with it
Old Nov 30, 2006 | 07:06 PM
  #25
abi_redy's Avatar
I beleive it is because of the fsi.. Even my 07 2.0t(6speed) is a littile loud compared to my Bimmer.
Old Nov 30, 2006 | 08:49 PM
  #26
socaljoe's Avatar
SoCal Crew Member
Mine is the same thing. It sounds almost like a diesel when stopped at a red light or when normally accelerating. It's the FSI that's causing it, try flooring it from stop and you'll hear a different kind of noise....a good noise (well to me at least)..it's like the engine has two personalities. One mellow and relaxed, the other, mean and pissed off
Old Nov 30, 2006 | 11:41 PM
  #27
onepoint8tee's Avatar
He said it sounds like a lawn mower or a diesel truck! Thats definately not normal even with a high CR or being tip.
Ok well if you other B7 owners say its normal i guess thats just how it is...
Old Nov 30, 2006 | 11:50 PM
  #28
tractioncontrol's Avatar
It also runs a roller rocker setup creating less friction to make 10.5 to 1 compression work. It's nothing like a 1.8t.
RichardCVan
Jul 16, 2010 09:38 PM
DankesterA4
Jun 14, 2010 12:32 PM
cumscrote
May 25, 2007 10:39 PM
Jeff
Jul 31, 2006 09:53 PM
classic079
Jun 10, 2006 02:02 AM
