New clutch with higher boost???
Old Sep 19, 2007 | 08:17 PM
kemp_travis's Avatar
Default New clutch with higher boost???
some guy i was talking to today said that before i put my car on 20psi(with the chip im getting)....i will need to get a new/performance clutch kit, cuz the stock one wont hold up...
is this true? if so, what brand should i go with that is good quality and affordable? oh and how hard is it to put a new clutch in my quattro?
Old Sep 19, 2007 | 08:21 PM
chaos92287's Avatar
Default RE: New clutch with higher boost???
stock clutch is fine. only if you go BT will you need a new clutch
Old Sep 19, 2007 | 08:24 PM
Belligerenceâ„¢'s Avatar
a K04 will be pushing the limits of the stock clutch too, and the PC-16 file will probably burn it up pretty quickly.
how many miles have you put on your car since you went K04 brian? how's your clutch holding up?
Old Sep 19, 2007 | 08:41 PM
chaos92287's Avatar
k04- 105,000 miles
still on stock clutch
clutch is officially toast right now. but that is only due to me letting my friend drive my car while i was drunk. he brought it back and my clutch was literally smoking. clutch started slipping after that and has been for the last year and finally jus crapped out on me last night
Old Sep 19, 2007 | 08:43 PM
Audi_Skydiver's Avatar
What chip are you getting?
Josh
Old Sep 19, 2007 | 09:43 PM
im trying inmotion
Old Sep 19, 2007 | 09:50 PM
onepoint8tee's Avatar
It seems whoever you are getting your information from, outside of www.audiforums.com, has no idea what their talking about. Stop listening to that jackass and start listening to us! If you read the stickies, you would know these things. Why dont you read the stickies?
https://www.audiforums.com/m_402135/tm.htm
Old Sep 20, 2007 | 12:34 PM
cincyTT's Avatar
I'm make believe
The stock a4 clutch is 240mm and those can do justunder 300ftlbs stock. A ko4 still wouldnt make higher than 265ft lbs
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
TomRitt
Feb 13, 2006 08:09 PM
clconversion
Jul 15, 2005 08:32 PM
David_K
Aug 12, 2004 01:41 PM
