New Question 1.8t
Old Jun 8, 2006 | 04:29 AM
spectrum's Avatar
Default New Question 1.8t
Should a 1.8t chipped run perfectly smooth?
Is it common to have vibration when accelerating?
Old Jun 8, 2006 | 05:05 AM
miked's Avatar
Default RE: New Question 1.8t
Yes it should. Thats not common. How violent is the shaking, and is it in any particular area of the car? Does it happen only at certain speeds? If so, you need to balance your tires.
Old Jun 8, 2006 | 06:50 AM
Dj Spiel's Avatar
I cant streess this enuff.
I believe this is 2nd or 3rd time I have seen this.
If your car is new... TUNE IT!
Oil Change
Spark Plugs
Balance Tires
When was your Tbelt done last?
Dont waste 600 on a chip if ur do for tbelt in next 3 months. If ur shi** snapps ur f****
Take it easy for at least 30-days. Dont boost alot. My 2 sense i didnt do this to my car I wanted to see if any problems came up. So far nothing so I drive a little more agreessily
Old Jun 8, 2006 | 10:59 AM
north5995's Avatar
Are you getting surging issues? There have been a few threads about it, most recently "A4 The Quattro". Search for it.
If you are having vibration, your car may need to learn the chip a bit more. Also try doing a throttle body adaptation. You can find the instructions by searching.
Old Jun 8, 2006 | 12:29 PM
spectrum's Avatar
Yes, slight surging issues. I'll try searching "A4 the quattro" and throttle body adaption alot to do after chipping. I thought i would just get it and be on my way! In my previous posts I thought maybe this was just common issue.
Would it take weeks to adjust to the chip?
ORIGINAL: north5995
Old Jun 8, 2006 | 12:36 PM
spectrum's Avatar
not a violent shake slight kind of like vibration sounds like base rumbling through the cabin!
ORIGINAL: miked
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
