New Turbo
Old Mar 7, 2007 | 03:51 AM
akielb's Avatar
Default RE: New Turbo
I would suggest checking out http://www. g-popshop.com you can either get a new k03 or a k03 changed into a k04 spec turbo - the K04 will run you around $600 for the turbo and install kit - plus you will need software from GIAC ($600) if you have a b5 or APR if you have a b6. K04 is the most reliable daily driver upgrade you can get - people say the larger BT setups are just as good but its your call. BT your looking at 3-5k. I say if your going to spend the $$ anyway spend a little bit more and get the K04
PS whenever you post a question like this or anything to do with you car - put year, model, engine, or anything else that will assist us in helping you
Old Mar 7, 2007 | 03:57 AM
eurodynasty's Avatar
thanks for the link it helps. I would go with the urgrade to the K04 but where would I get the software to urgrade the ecu?
o sorry, this is for a 99.5 A4 B5 1.8T FWD
Old Mar 7, 2007 | 04:09 AM
Jeff's Avatar
Zombie Defense Force
i ran a t3t4 on a stock exahsut for a long time. didnt blow anything
Old Mar 7, 2007 | 04:10 AM
scotts custom's Avatar
I am going to get a k04 but what is the difference between a k04 and a k04-015? is it just more power?
or are they the same ?
Old Mar 7, 2007 | 04:21 AM
Belligerenceâ„¢'s Avatar
ORIGINAL: Bondga
IM not to sure about that. I'm pretty sure that you some amount of back pressure to completly spool the turbo
well yes, of course. let me clarify my statement. I was referring to the old-school train of thought that states that too free-flowing an exhaust system will not create enough backpressure to spool a turbo properly. this is false, and has been proven many times.
Old Mar 7, 2007 | 04:30 AM
A4Rollin's Avatar
hey scotts custom, the ko4-015 has a little more power to it and sounds a little better when spooling up. Im not sure if the 015 or 015s is ported and the blades are trimmed.....either way they sound bad ***!
Old Mar 7, 2007 | 04:36 AM
nvm
Old Mar 7, 2007 | 04:41 AM
  #18
A4Rollin's Avatar
HE is not a web site.....its the guy that asked a question above, lol
Old Mar 7, 2007 | 04:46 AM
  #19
where are other sites to get these? besides the one akielb posted, and do all require an ecu flash or watever?
Old Mar 7, 2007 | 04:52 AM
  #20
A4Rollin's Avatar
atpturbo.com
awe-tuning.com
I would recommend getting a chip than just the occasional flash, for b5's GIAC is a very good chip
