Sponsored by:
Sponsored by:
night's gettin' longer
Old 06-15-2005, 12:14 AM
insuite's Avatar
Default night's gettin' longer
I'm putting new tie rod ends (among other things) in my '00 1.8TQ. It seems to be a really easy job, with the exception that I can't get the bolt that goes thru the indent on the tie rod end and the upper control arm out! Appears to me to be rusted in place pretty darn good. I've tried raising, lowering the jack (holding the hub in a relatively 'normal' position even though the car's on jack stands) and spraying the crap outa it with WD40 trying to break what I suspect is a rust-hold on the bolt.
Any suggestions? It's getting later and I'm getting nowhere. I could really use a great idea from someone.
Thanks!
Old 06-15-2005, 12:18 AM
black b5's Avatar
Default RE: night's gettin' longer
do you have a impact wrench?
if so hit that bolt with the impact till it spins freely, then a few shots with a punch and hammer will finish her off
Old 06-15-2005, 12:49 AM
insuite's Avatar
got one ... working on the other side. now the problem is i can't break loose the tie rod end from the nut (at the tie rod boot). it's just all locked up and i can't hit that one with an impact wrench. any suggestions there?
thanks for the help.
Old 06-15-2005, 12:36 PM
jukeit's Avatar
Just so I understand correctly, you are putting a wrench to the nut at the boot and can't get it loose right?
Old 06-15-2005, 12:48 PM
jukeit's Avatar
Scratch the question. Saw your other post.
Old 06-16-2005, 12:17 AM
BFlan2001's Avatar
this was just posted on another thread, your best bet is to remove the tie rod assembly at the inner end, that way you have full access to the seized end
SMoLiK
01-10-2007 07:35 AM
1BADS4
06-14-2006 04:38 AM
impaler2383
05-11-2006 12:15 AM
1.8T5spd
06-04-2004 08:32 PM
Quick Reply: night's gettin' longer
