No headlights, no AC, no horn, no windshield wipers, no turn signal
Old Aug 27, 2007 | 05:03 PM
dombombBMX's Avatar
Default RE: No headlights, no AC, no horn, no windshield wipers, no turn signal
when i went to the stealership i asked if they had a relay switch or whatever, and they said there was no such thing? only and x relay or some shiz..
but i just ended up getting the ignition switch and that was the solution
Old Aug 27, 2007 | 05:18 PM
bartvaio's Avatar
of course they told you that, because you asked for a relay switch [:-], you dont go and buy a load reduction relay, you have to buy any of this two:
Part numbers:
443 951 253J (BLACK MARKED "213"), is what was shipped with the car
Superceded by:
8D0 951 253 (GREY MARKED "370"), is the replacement part
So, this are RELAYS, not load reduction relays (wich is the relay function, not its name)
Old Aug 28, 2007 | 12:14 PM
Ruckuz's Avatar
Thanks fellas for all your help. I'm very appreciative of it. Will check relay and if that doesnt work will check ignition switch.
Old Aug 28, 2007 | 06:57 PM
Red Baron 97's Avatar
Check with Audi of America. See if you qualify for the ignition switch recall (JS campaign). Dealer will replace it for free. Dealerreplaced minelast month on a '97.
Old Jul 31, 2015 | 06:34 PM
rsmith101's Avatar
Default rsmith101@mygrande.net
Originally Posted by techbod
hopefully this is the problem relay as bartvaio says
[IMG]local://upfiles/12092/68FD2B57F445428D96E96F384781C1AC.jpg[/IMG]
Did this fix the problem??
Old Feb 24, 2022 | 01:18 AM
dzovas89's Avatar
Originally Posted by Ruckuz
Sup everyone,
I'm new here and this happend to me yesterday. I have a 98 A4 Quattro, 5 speed, v6. Last night when I turn on my car, my headlights, AC, windshield wipers, turn signal, and horn doesnt work. The funny thing was that everything was working fine a few hours ago. Could it be the fuses? It strike me as odd that it could be the fuse because a lot of things are not working. I can't fathom the idea that all these fuses blew @ the same time. Has anyone experience this before? What could it be? Could it be the computer because I heard Audi has A LOT of electrical problems. Many thanks.
Hello, people, 15 years later. I had same problem with my A4 '01. I couldn't find a good master. Some said it was an ignition lock, others a relay, still others expensive electronics. But no one could solve that problem. In the end, I accidentally determined that the problem was the wires leading from the chassis to the driver's door. The insulation of the wires cracked and when it came in contact with water, a joint was made. I have bridged all 8 wires and I no longer have that problem.
MARKANTO13
Jun 25, 2021 04:27 AM
ACEQUATTRO
May 23, 2017 06:48 PM
dge101
Dec 29, 2007 12:02 PM
lancemsnyder
Jun 12, 2007 04:07 PM
