No heat
Old Nov 20, 2005 | 06:51 PM
kingming's Avatar
Default No heat
Any idea on my 97 A4, I Have no heat… If the car gets up to operating temp and I have RPMS up to 3-4 grand heat slowly starts to come up after it idles
The heat goes away.
Old Nov 20, 2005 | 07:08 PM
david9999's Avatar
Default RE: No heat
Have you done anything recently on the car? Changed coolant, or filled it up?
Could be air in the heater core or blocked neater core.
Check the hoses in the engine compartment going to and from the heater core at the firewall.
Old Nov 21, 2005 | 12:41 AM
kingming's Avatar
Default RE: No heat
I fludhed out the heater core and i am getting flow in eiter direction. I used the outlet hose to bleed the system and i did not seem to have any air. I am thinking the t-sata may be stuck open but then when the car gets hot i should have heat all of the time.. I dont know....
Old Nov 21, 2005 | 12:45 AM
david9999's Avatar
Default RE: No heat
If you have access to a VAGcom see if you have any codes in the HVAC system
cu52
Oct 28, 2009 11:50 AM
lorencew
Feb 9, 2009 01:15 AM
Excape
Sep 19, 2008 03:07 AM
jimmyt853
Feb 21, 2007 05:50 PM
shelby69
Feb 15, 2007 09:35 PM
