noise from rear wheel
Old Mar 28, 2006 | 07:31 PM
DVA's Avatar
DVA
Default RE: noise from rear wheel
ORIGINAL: xx18quattroxx
thank you, simple enough, if i can rebuild the motor, im sure i can handle a wheel bearing... but you are sure thats what it is?
well I`m sure it isn`t I have the same problem it`s only when up to 50 mph and louder when I turn left a little... but it stops to low speed and when I turn right also.. I tough there is something wrong with the braking pads and rotors but it isn`t. don`t know what to say..
oh btw the noise it`s coming from the front driver side wheel..
Old Mar 28, 2006 | 07:34 PM
BFlan2001's Avatar
ORIGINAL: DVA
i do...it's the wheel bearing.
Old Mar 28, 2006 | 07:54 PM
BadLuckAudi's Avatar
LOL how many times do we need to say wheel bearing before they figure it out lol
Old Mar 28, 2006 | 08:26 PM
fastmayte's Avatar
Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing Wheel Bearing[:'(][:@][8D][X(][&o][:-][>:][&:]
rhohmann
B7 Models
Feb 1, 2013 12:21 PM
dave_j
Jun 3, 2011 07:57 AM
jeffreykauffman
Audi Q7
Oct 19, 2010 09:40 PM
fromerich
Oct 19, 2009 10:59 AM
czwalga
Feb 19, 2008 02:55 PM
