NOISEY TURBO PROBLEM
Old May 5, 2006 | 09:43 AM
stephen.ford@tesco.n's Avatar
Default NOISEY TURBO PROBLEM
The turbo unit on my A4 1.9 TDI makes a sucking/ rubbing noise when I lift off the accelerator as if the fins are rubbing on the casing.
It is most noticable when I rev the engine whilst not in gear & lift off the acceleretor quickly.
I cannot feel any play on the shaft & it spins ok
Done 85K
Is it about to explode?
Old May 6, 2006 | 07:46 PM
dankhound's Avatar
Default RE: NOISEY TURBO PROBLEM
Are you sure its not the diverter vavle making noise?
Old May 6, 2006 | 09:00 PM
Jovian's Avatar
I had an issue where I had a ticking noise where I let off the accelerator. It turned out the wastegate on the turbo was loose and would rattle when it was supposed to be closed. Hope this helps
john millington
Aug 11, 2014 04:29 AM
Quagmire
Jul 21, 2012 11:44 AM
Lsand
Sep 23, 2007 10:31 AM
lidonnit
Jul 27, 2005 02:34 AM
BostonS4
Oct 19, 2004 05:21 PM
