NOOOO did i screw this up?
ORIGINAL: Mr_You
I think GIAC is 91 only.
Either way 91 or 93 is fine its not a terrible difference between them its not like your car is going to completely **** up if you go with a higher octane its probably programed for 91 seeing how giac doesnt offer a 93 oct program but you might see a better range in gas mileage if you go with 93 consistantly. I had giac on my other audi running pc16 and i ran 93-94 and it ran great.... till it got stolen.
ORIGINAL: dafrazi
Yes it does. Premium is not that expensive. $0.20 per gallon times 15 gallon average fill up is $3.00 per tank. I fill up every 2 weeks so it's an extra $6 a month. If you fill up every week, it's an extra $12 a month.
Also, especially in winter, the difference between 91 and 93 won't hurt your car. Get 93 to be safe, since, as the immutable logic of math tells us, it's a lot lot cheaper than a new engine, but you shouldn't worry. Over time, higher octane than optimal will clog your cat, ruin your O2 sensor, etc etc, since the higher octane can't be used, and is just turning into unburnt buildup. Lower octane will cause you to "ping" or detonate when combustion temps get high, and your ECU will adapt to it, but it's needless power loss. Just call who chipped you and ask.
rnbguy
Feb 8, 2006 02:29 AM
