NOOOO did i screw this up?
Old Feb 10, 2006 | 07:36 PM
mjvss21's Avatar
Default RE: NOOOO did i screw this up?
ORIGINAL: Mr_You
I think GIAC is 91 only.
and the reason they have a 91 0ct and 93 oct is because some areas dont have 93 octane, it will never hurt you to put in 93 if you got chipped for 91, FYI
Old Feb 11, 2006 | 02:54 AM
david9999's Avatar
GIAC doesn't make a 93 Octane chip.
APR makes both 91 and 93 Octane.
Old Feb 11, 2006 | 05:18 PM
a4's Avatar
a4
David- why then would they as if I use 91 or 93 on the form?
THx guys,
A4
Old Feb 11, 2006 | 06:20 PM
tip5's Avatar
Either way 91 or 93 is fine its not a terrible difference between them its not like your car is going to completely **** up if you go with a higher octane its probably programed for 91 seeing how giac doesnt offer a 93 oct program but you might see a better range in gas mileage if you go with 93 consistantly. I had giac on my other audi running pc16 and i ran 93-94 and it ran great.... till it got stolen.
Old Feb 11, 2006 | 06:25 PM
Karl's Avatar
ORIGINAL: CRAZYHAWK
Call the company that did your ECU. If they can't help, fill half way with 91. If it knocks, add 93.
its not going to knock on 91 octane
Old Feb 12, 2006 | 03:35 AM
sandnsnow24's Avatar
wow man you don't own a race car....... damn
the difference between 91 and 93 doesn't matter at alllllllllllllllllllllllllllllllllllllllll!!!!!!!
Old Feb 12, 2006 | 05:47 AM
Yuikio's Avatar
ORIGINAL: dafrazi
Yes it does. Premium is not that expensive. $0.20 per gallon times 15 gallon average fill up is $3.00 per tank. I fill up every 2 weeks so it's an extra $6 a month. If you fill up every week, it's an extra $12 a month.
Woohoo! Another convert to the side of logic and reason.
Also, especially in winter, the difference between 91 and 93 won't hurt your car. Get 93 to be safe, since, as the immutable logic of math tells us, it's a lot lot cheaper than a new engine, but you shouldn't worry. Over time, higher octane than optimal will clog your cat, ruin your O2 sensor, etc etc, since the higher octane can't be used, and is just turning into unburnt buildup. Lower octane will cause you to "ping" or detonate when combustion temps get high, and your ECU will adapt to it, but it's needless power loss. Just call who chipped you and ask.
Amybc96
B7 Models
Jun 29, 2015 07:37 PM
audia6s
Apr 16, 2008 05:33 PM
A4orced
Feb 11, 2006 03:06 PM
AudiZen
Sep 3, 2005 12:52 AM
