NOT LOWERING but RAISING it??
Old Sep 9, 2015 | 04:17 AM
JungleAudi's Avatar
Default NOT LOWERING but RAISING it??
Yes, I know this sounds crazy — but drastic environments require drastic measures: Where I live, every 3 blocks there are speedbumps....
And their Mount Everest-like dimensions are as hazardous to your splitter &amp as snowstorms at 29,000ft.
And the potholes rival the depth of the Grand Canyon (not much tourism, though).
Welcome to my new home — Lima, Peru, where 9 million people have to put up with these anti-tuning politics.
QUESTION: For the above reasons, I'm thinking of not lowering my car, but instead putting tall tires on.
What is the biggest diameter that will fit my fenders (stock suspension)?
I'm new at this! What thoughts and recommendations do you have?
I'm new at this — trying to learn. And I need to figure out, how to say all these things in Spanish, cause thats what my mechanic speaks!
JungleAudi
A4 2002 3.0L
Old Sep 14, 2015 | 01:01 PM
rhodes991's Avatar
If you decrease your wheel rim size (17 or 18 most likely) then you can put tires with beiiger sidewalls on to "cushion" the ride more. It will affect handling which I am guessing you really don't care about. I think you should be able to google for a tire diameter calculator to figure out what sizes will fit and keep your speedo as close to accurate as possible.
Old Sep 15, 2015 | 01:59 AM
JungleAudi's Avatar
Yeah, I found the tire diameter calculators. They help some . The most helpful I found are:
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Tire Size Calculator
Sure, by reducing the wheel rim, I can then increase the tire sidewall. But that leaves the diameter of the whole thing still the same. I want the tire/rim assembly to be taller/ have a larger diameter.
So, that's the QUESTION: What is the tallest tire diameter that fits into the wheel well of an Audi A4 (B6, 2002), 3.0L FWD, stock suspension -- without rubbing on bumps and dips?
Old Sep 15, 2015 | 02:16 PM
rhodes991's Avatar
Now that is a tough question. I am guessing not much bigger as things are pretty tight in the wheel well already. Might be able to take it up a diameter or two.
mafpolo
May 10, 2015 12:03 PM
Mike-2ptzero
Mar 30, 2011 01:27 AM
DurtyTT
Jun 4, 2007 10:20 AM
Mystro
Jun 24, 2006 09:35 PM
rjplunk9
Nov 30, 2005 05:55 PM
