O2 Sensor causing car to stall?
Old Jan 30, 2007 | 02:52 PM
zchb9's Avatar
Default O2 Sensor causing car to stall?
Hey all, my check engine light came on about 2-3 weeks ago before I came back to school. I had a local shop check it and they said it was the O2 sensor. Today when I stopped at a stoplight it had a jumpy idle and then stalled 3 different times. Does that really sound like the O2 sensor? What else could it be? Thanks all.
Old Jan 30, 2007 | 02:55 PM
techbod's Avatar
Default RE: O2 Sensor causing car to stall?
only guessing without a fault code but yes the O2 sensor could cause that plus lots of other things
Old Jan 30, 2007 | 03:00 PM
klum00's Avatar
could be the MAF or TBA also...
Old Jan 30, 2007 | 03:50 PM
wood_e's Avatar
Try cleaning your MAF.
Old Jan 30, 2007 | 04:08 PM
akielb's Avatar
If they checked the codes for you hopfully they cleared them - check the codes again and verify that its the same code.
Old Jan 30, 2007 | 06:37 PM
david9999's Avatar
And post the number here. Doesn't sound like an oxygen sensor
Old Jan 30, 2007 | 06:40 PM
hb972.8q's Avatar
that is what i replaced whenmy carwas doing the same thing
chosos
Jun 26, 2012 06:29 PM
nicolehender
Aug 15, 2011 05:54 PM
pbrules10
Dec 31, 2010 04:21 PM
GL8386
Nov 15, 2006 03:42 PM
audienvy
Mar 8, 2006 04:37 PM
