oil change?
Old Jan 9, 2005 | 03:33 PM
turbo's Avatar
Default oil change?
I just got a 10 pack of oem bosch filters for my 02 a4 off ebay and I am going to start using synthetic oil. How often should I chang oil?
Old Jan 9, 2005 | 03:34 PM
turbo's Avatar
Default RE: oil change?
is it 5000 or more
Old Jan 9, 2005 | 04:07 PM
CRAZYHAWK's Avatar
Up to 10K , depending on your driving.
Old Jan 9, 2005 | 04:09 PM
audiboy1618's Avatar
Do you have any mods? if so i change mine arounf 3k.
Old Jan 9, 2005 | 04:46 PM
CRAZYHAWK's Avatar
audiboy1618 , I have no Mods. Road & Track has a column in the Technical Correspondence of the Feb. 2005 issue. Someone with a BMW who uses Mobil 1 , as recommended , wanted to know if the oil shoud be changed more often than the 15K requirement by BMW. They commented , the engine will only outlast the rest of the car by doing this. However , there are many variables: short trips in cold weather , dusty conditions , and Mods the increase the oil temperature. You can check your oil every 1000 miles. Pull the dipstick and rub some oil between your fingers. If it's smooth good.
Old Jan 9, 2005 | 05:09 PM
turbo's Avatar
I for now have the revo flash but plan to do turbo upgrade soon .
Old Jan 9, 2005 | 05:17 PM
Transverse's Avatar
10k!? Are you NUTS!? Oil change every 3500-4k...no questions...just do it! If you want your baby to last you gotta treat her right! I usually change my oil every 4months even if I haven't drivin a lot on it. 10k is almost a year of driving for an average driver. An oil change is possibly the best thing you can do to insure the life of your engine...
-T
Old Jan 9, 2005 | 06:41 PM
Crazyhawk, that bimmer is n/a, not turbo. Like Tranverse, around 4k. My tuner said 3k just to be safe.
Old Jan 9, 2005 | 07:47 PM
John_E's Avatar
ORIGINAL: Transverse
-T
Spot-on, particularly for cars subjected to urban driving, which is the ultimate in "severe service." With the 1.8T's infamous sludge problems, a 5K mi = 8K km OCI is only for those who do lots of long easy highway drives.
Incidentally, "every 4 months" is what the original owner's manual says for my son's 1969 Camaro. Oils have improved, but engines, particularly the turbos, have gotten much hotter and harder on oils.
CRAZYHAWK's Avatar
I said there are many variables.
