Oil change problem
Old Jun 7, 2007 | 09:22 PM
TakingBackSomeday's Avatar
Default Oil change problem
I am changing the oil for the first time on my '01 a4 2.8l quattro and i've drailed the oil from the plug no problem but the filter that is on there will not budge. Help please!
Old Jun 7, 2007 | 09:34 PM
TDRILL's Avatar
Default RE: Oil change problem
They make wrenches specifically for getting the filter off. Personally, the only thing I ever use is a strap wrench. When you reinstall it, make it firmly hand tight. Don't tighten it with a filter wrench or anything as it makes it a huge pain to get off.
I suggest you run to walmart and get a strap wrench (decent size one like 10" long) or get a filter wrench.
In a pinch some people will tell you that you can drive a screw driver through the filter to get leverage. People do it, but only do it as a last resort. Once you puncture it, there is no turning back. You are stuck right now, but if nothing else, you can put oil in without changing the filter this time and get a wrench for next time.
Old Jun 7, 2007 | 09:37 PM
I have a strap wrench but i'm pretty sure whatever idiot changed the oil before me didn't lube the ring before installing the new one and now this one is fryed on there. I think i'm going to try the screwdriver technique.
Old Jun 7, 2007 | 10:05 PM
CLX's Avatar
CLX
Zombie Defense Force
The screwdriver technique works really well. It's not like you're using it again.
Old Jun 7, 2007 | 11:20 PM
wemmington's Avatar
I had to drive a screwdriver through mine the last time I changed my oil and it does work very well but be prepared to get oil all over. When I got done it looked like I took a bath in oil.
Old Jun 8, 2007 | 12:08 AM
SAudi's Avatar
true for the screw driver method thats what i always use, just be ready for the oil that squirts out the first time and then the oil that drips out when your turning it.
Old Jun 8, 2007 | 04:56 AM
Trey25's Avatar
I kinda like doing the screwdriver method, not on my car though.
Old Jun 8, 2007 | 12:28 PM
Thanks for the help everyone. It was so frustrating last night that some people out there don't know how to do a proper oil change.
Old Jun 8, 2007 | 12:41 PM
veloracer's Avatar
It's always harder the first time you do it on a new car. When I did my first oil change on my A4, it took me awhile. It's time for me to do another one, but now I know how to get the damn skidplate off, & know where everything is.
knole68
Jun 21, 2015 08:24 PM
audilover78
Jul 9, 2013 09:41 PM
Rickypr
May 2, 2010 12:44 AM
adema69
Aug 16, 2006 07:44 PM
Firestarter1984
Mar 27, 2003 11:09 PM
