OIL Consumption
Old Oct 20, 2006 | 05:40 PM
acetrebo's Avatar
Default RE: OIL Consumption
Mine does not consume any noticable oil at all.
But, I dont have 156k on it either. Still, sounds like a problem to me. Got to be a leak somewhere, either a gasket, or you are getting blow-by on the rings.
Try a compression test, and maybe some oil for high mileage engines that has a seal conditioner in it.
Old Oct 20, 2006 | 05:43 PM
acetrebo's Avatar
ORIGINAL: duburban
Update on the oil..
Thanks for the tips guys. I ran into my mechanic the other day and he informed me that when the dipstick reads nearly dry there is still plenty of oil in the engine. I was under the impression that the dipstick read all 5 or 6 quarts not just 1 quart. By the way, my engine compartment is very clean. No leakage just burns a quart every few thousand like normal. So i'm feeling good about the oil how about my radiator? Is this a really complex job? Or something i could do with a repair manual and basic tools? Anyone replaced their radiator that has tips?
Rad should be fairly easy DIY.
Probably should remove bumper for easier access, its an easy DIY, if you have a bently or haynes that will help. Otherwise, read the beginning of a t-belt change write-up, removal of the rad is part of that process.
Old Oct 20, 2006 | 07:58 PM
duburban's Avatar
Hey Ace, Where do i find the beginning of the T-Belt Change Write-Up? I've looked around a bit but i can't find it.
Thanks!
Old Oct 20, 2006 | 10:33 PM
TDRILL's Avatar
TIMING BELT WRITUP:
http://www.audiworld.com/tech/eng35.shtml
Old Oct 20, 2006 | 11:02 PM
duburban's Avatar
Thanks for the link! One more question on the radiator. Which radiators should i be looking at? Are some going to last longer than others? Perform better? Prices on generic auto suppliers are around $170 to $200, what about the nameless radiators on ebay "brand new" for $100? Thanks again!
Juddsmith
Sep 24, 2014 11:05 AM
whoisthis
B7 Models
32
Nov 16, 2010 04:43 PM
wallj
Feb 7, 2010 06:50 PM
ace2525
Aug 26, 2007 09:43 PM
ou51
Dec 24, 2006 12:33 PM
