oil presure
Old Feb 5, 2007 | 03:18 PM
ski911's Avatar
Default oil presure
When ever I go into the mountians going up a pass, the last 2 times. the oil pressure light comes on for about 10 seconds then goes off, I have full oil. what could this mean, if it is just the oil pressure sensor, are thoes expensive? and are they hard to put in?
is this a common problem?
Thanks
Old Feb 5, 2007 | 03:19 PM
wood_e's Avatar
Default RE: oil presure
What year, engine? If you have a 1.8t you probably have sludge. How often/where do you do your oil changes? Do you have a warranty?
Old Feb 5, 2007 | 03:32 PM
ski911's Avatar
yeah, that might help..its a 98 2.8, oil changes every 3500 with semi senthitic, just had it changes about 1 month ago and spark plugs replaced. no warranty 114K miles, usualy do the changes myself, but this time thecar flooded and had it towed in to a shop and they did it with the plugs.
Old Feb 5, 2007 | 06:28 PM
wood_e's Avatar
Looks like you have a good service record in your ownership. What brand oil are you using (just curious)? I would say either
1) your engine is starved for oil pressure at some point or...
2) your pressure sender is on the fritz.
Only way to be sure is have a gauge hooked up to check your oil pressure. It would be a good idea to run an AutoRX treatment. I did one and I was pleased with the results, although i had no pressure issues.
How'd your engine get flodded?
avopaul
Mar 8, 2016 07:14 AM
94CAB
Aug 9, 2008 01:31 PM
Frenchie
Jun 8, 2007 04:55 PM
JohnnyBravoA4
Oct 8, 2006 06:48 PM
virus
Sep 25, 2006 12:22 PM
