Oil temp
Old Apr 24, 2006 | 07:55 PM
2000A4Turbo's Avatar
Default Oil temp
has anyone had a problem with the oil temp gauge working normally around 200 degrees then just randomly go back to the 150 resting point like its not working then back to 200 again and stays....had the same problem with coolent temp gauge but replaced the thermostat and it stopped... anyone had this happen?
Old Apr 24, 2006 | 07:57 PM
BadLuckAudi's Avatar
Default RE: Oil temp
mine did some wierd stuff like that but it just quit working all together now
Old Apr 24, 2006 | 08:35 PM
Jovian's Avatar
Nope mine hasnt done that before. Could be slowly dieing.
Old Apr 24, 2006 | 10:01 PM
ah.... its weird...works sometimes.. but i will just go to a wrecking yard and see if i can score a whole new sensor just incase....could be a bad gauge in the cluster maybe. oh well if anything i will just get some aftermarket gauges and do it that way.
Old Apr 24, 2006 | 10:05 PM
north5995's Avatar
Don't get one from a junkyard, you may be picking up another bad one. Just buy a new one they aren't that expensive.
Old Apr 25, 2006 | 12:14 AM
yeah your more then likely right...i will check how much they are tomorrow....just figuring it was expensive since it is for an audi...was a previous honda owner where everything was cheap. so this is all new to me kinda
toboater
Oct 26, 2010 12:15 PM
zer0vette
Jul 21, 2010 10:30 PM
kbrookst
Oct 24, 2009 06:37 PM
danmcc86
Feb 12, 2009 11:49 PM
