only for experts
Old Dec 8, 2004 | 11:13 PM
alejandrorodrigu's Avatar
Default only for experts
oil filter: 1 valve vs 2 valve in an 1.8t (stock is 1 valve), can this damage the engine?
Old Dec 9, 2004 | 12:10 AM
PaulA4's Avatar
Default RE: only for experts
you mean the type with the built in bypass valve?
Old Dec 9, 2004 | 10:50 AM
yes
Old Dec 9, 2004 | 11:41 AM
PaulA4's Avatar
I don't see why it should cause a problem, the bypass valve is only there in the event of the filter medium becoming blocked or collapsing, aslong as it's designed for the thread on the 1.8t engine it should be ok.
One thing i'd check though is the psi it opens at as the audi oil system might run above this and result in unfiltered oil at all times. Why exactly do you want to run one?
Old Dec 9, 2004 | 11:44 AM
Jestnomen's Avatar
6th Gear
Are you contemplating using a different filter than oem? If so which ones?
Old Dec 10, 2004 | 02:28 AM
first sorry about my english (no my native language)... ok, i took my car to the audi dealer to change the oil, then i saw the original oil filter for the 1.8t (smaller with a price of us$3 ) and the s4 oil filter (bigger size with price: us$45 ), then i ask for the dealer to put in may car the s4 oil filter, then the dealer ask me: why you wan´t this ?, and i say just put it, the the man says okok just remember that hte original has one bypass valve and the s4 has two. and my question is if this change can damage my car ?
Old Dec 10, 2004 | 11:55 AM
Jestnomen's Avatar
6th Gear
I think Audi just came out with a new larger oil filter for the 1.8t due to the oil sludge problem.
AudiCoupeV6
Dec 4, 2008 01:21 AM
southcoast
Jan 10, 2007 07:31 AM
ininkus1
Sep 10, 2006 01:11 PM
JG
Mar 31, 2006 09:15 PM
rnbguy
May 21, 2005 01:23 AM
