only starting when holding the gas
Old Jul 31, 2006 | 07:55 PM
  #31
tbehling's Avatar
Default RE: only starting when holding the gas
hasn't happened since saturday... do you think if fixed itself?
Old Aug 7, 2006 | 07:49 PM
  #32
tbehling's Avatar
still having this problem, someone suggested that it could be the fuel pressure regulator?> or maf sensor
Old Aug 7, 2006 | 07:59 PM
  #33
techbod's Avatar
so you checked all the air hoses and vacuum pipes for leaks?? MAF would leave a code also check the pipe from the MAF to the intake for splits, fuel pressure possible and next would be the throttle body like sticking butterfly valve and idle control actuator which is part of the throttle body which might need a clean out, just ideas as to what the problem could be since there were no codes
RagtagXMASTER
Jan 12, 2013 01:33 PM
njs42002
Oct 5, 2006 07:26 PM
owen
Nov 10, 2005 03:27 PM
a4autocrossr
May 25, 2005 06:39 PM
