opinion needed!
Old Jul 17, 2006 | 01:06 PM
laxhuskie9's Avatar
Default opinion needed!
Well, I have a bad front upper? control arm and it's been bad for about six months (driven on for maybe 3). I want to get the control arm replaced up at school because it's a hell of a lot cheaper by this guy who owns his own shop. He installed my shocks and springs for $600 cheaper than a local shop around here was gonna do it for, so I know he'll give me a deal on this.
My question is, if only one control arm is bad, how safe is it for me to continue to drive, with it needing replacement? I'm going up to school in September, should I be okay until then??
thanks
Old Jul 17, 2006 | 01:13 PM
onepoint8tee's Avatar
Default RE: opinion needed!
Typicaly its the bushings that wear out prematurely and cause metal to metal contact which generates the notorious clunking noise on bumps and turns. The metal joints will wear away on each other and eventually break because of the stress that is being put on that particular spot/joint. After 6 months, i dont think anything is gunna break soon, but obviously get it taken care of asap cuz you never know and if one breaks at highway speeds that could be dangerous. Kinda like driving on a bad cv joint.
Old Jul 17, 2006 | 01:14 PM
smokeU's Avatar
I'm not sure about your question. sorry but how much did it cost you to get your suspension put on? I have a set of shocks and springs sitting in my garage and was wondering how much I need in order to finally get my car lowered. thanks
Old Jul 17, 2006 | 01:23 PM
laxhuskie9's Avatar
Well shockingly, the guy only charged me $250 to get them installed, and I bought the whole set-up on ebay/tirerack for roughly $550 total. The shop near me was gonna charge me $1200 for install and to order the suspension thru them.
**so i guess it was about $400 cheaper, my bad.
Old Jul 17, 2006 | 01:43 PM
wolfdog's Avatar
ORIGINAL: onepoint8tee
I hear a noise when I hit bumps/holes and it comes from both sides. It sounds like someone jingling keys or jingling a handfull of change but really quick, a split second. It's definitely not a clunk or any of the other sounds described when doing a search but has me curious.
I can only hear it with the windows down. I thought it might be normal since both sides of the car do it. There's no play in the steering wheel and I've gotten out and pushed down on the corners repeatedly while parked to see if I hear it but nada. Is this sound normal? Thanks.
Old Jul 17, 2006 | 01:56 PM
smokeU's Avatar
yeah thats about what i figured on paying. what setup did you go with? how much lower? and how long did the install take?
Old Jul 17, 2006 | 02:01 PM
laxhuskie9's Avatar
Bilstien shocks w/ H&R springs...guy had my car for a day to install (don't know the exact hours he worked on it...maybe 3-4hrs?). It lowered it about 1.25" in front, and 1" in back.
Old Jul 17, 2006 | 11:23 PM
Papachristou's Avatar
i would try and get it done ASAP, cause u never know...
off subject but where did u get the zimmermans and do u like them?
mtroxel
Jul 30, 2014 12:26 AM
amhobbs
May 10, 2013 11:14 AM
star
Oct 23, 2007 05:24 PM
mattn2005
Sep 19, 2006 04:01 AM
18T
May 30, 2006 04:22 PM
