Outside temperature display?
Old Feb 4, 2008 | 09:29 AM
mirkocrocop's Avatar
Default Outside temperature display?
Hi... I have a question... I have Audi A4 1.6 1998 b5, AHL engine... and i don´t have onboard computer... but i read in my manual that my car should have temperature display on board panel (see picture that i posted)... since i just bought car i dont know is this actually there or some fuse dont work etc... SO the question is... Does my car have that option but display somehow doesnt work... OR my car doesnt have that option...
10Q for answer in advance...
enjoy
[/align]
[IMG]local://upfiles/28924/EF01A3BD05784E9F85A86B14DD7AD4D3.jpg[/IMG]
[IMG]local://upfiles/28924/8C61C937AA8148CB959C0F7A20223558.jpg[/IMG]
Old Feb 4, 2008 | 01:26 PM
MrFlippant's Avatar
Default RE: Outside temperature display?
Could be the light bulb that illuminates that display is dead. When I bought mine, the bulb behind the odometer was out - cost me one hour of labor to have it replaced. Try starting the engine and then shining a flashlight on it from an angle; if you can see the temperature display then, you just need to have the bulb replaced.
Other than that, I don't know. Maybe someone else has another idea.
Old Feb 4, 2008 | 04:21 PM
McGovs2.7TB5's Avatar
I'm not sure if the switches are the same year to year but on mine you can turn that display off but pressing the button the bottom of the wiper stalk, and you can use the same button to reset mpg info, avg speed, ect., by pressing and holding until it resets. Hope that helps some.
Old Feb 4, 2008 | 05:02 PM
MrFlippant's Avatar
ORIGINAL: McGovs1.8B5
I'm pretty sure that's only on '99.5+ facelift A4's.
Old Feb 4, 2008 | 07:13 PM
ImTheDevil's Avatar
Correct - my 99 doesn't have it. My outside temp display will occasionally not come on. I have no idea why, but then awhile later it'll reapppear when I restart the car. Probably just a gremlin somewhere that is worse on your car than mine.
Old Feb 4, 2008 | 08:22 PM
FASTER's Avatar
Tech Slut
your car may not be equipped with it, im not sure... if you get on the ground under your front license plate and look up inbetween the condensor/radiator and bumper, you will see a little black spark plug resmbling thing (thermo) with a wire attached to it, if you dont have one, you most likely dont have an outside temp reading.
Old Feb 5, 2008 | 03:11 AM
ORIGINAL: FasterA4ThanUrs
your car may not be equipped with it, im not sure... if you get on the ground under your front license plate and look up in between the condenser/radiator and bumper, you will see a little black spark plug resembling thing (thermo) with a wire attached to it, if you don't have one, you most likely don't have an outside temp reading.
I looked and i have that... And i will try with flashlight and we will see... 10Q for answers to all of you... I actually just wanted to know does my Audi has that option at all... cause i don't have any friend with that car and i cannot compare... So it must be there... I will go to car electrician. 10Q once again... Oh and McGovs1.8B5 my car doesn't have any buttons on wiper stalk... as i said i don't have on board computer... but 10Q for your effort.
Old Feb 27, 2012 | 11:31 PM
sssstew's Avatar
So can anyone confirm this?
My 1998 A4 Avant doesnt show on the display but in the attached image which i grabbed of a vid on the net seems to show one, so i think maybe i should?
Im going to check with a torch like mentioned before also.
Parker0217
Nov 21, 2013 07:03 AM
peterbr17
Jul 10, 2009 06:59 AM
Reckless
Jun 20, 2006 05:39 AM
cptarmy
Feb 3, 2006 02:44 AM
robsilvr85
Nov 25, 2005 05:23 AM
