please respond if you know anything
Old Jan 20, 2007 | 12:15 PM
joelml's Avatar
Default please respond if you know anything
i have been thinking about getting an upgraded turbo. the k04 are expensive and are hard to find in the states. i found a turbo made by "G-Pop". they get k03 and put k04 internals inside. they state that the turbo is just as good as and in some cases even better. does anyone know anything about this and would this be a good alternative. the turbo is only $615.
any info would help.....
Old Jan 20, 2007 | 12:19 PM
quattrosedan's Avatar
Default RE: please respond if you know anything
They probably use k04 internals with a k03 housing. If that is the case, you will have better bottomend than a normal k04, but not as much top end asa k04. Imo, I wouldnt get it. It will make a noticeable difference, but after going bt, it is hard to say a k04 will make someone happy....
Old Jan 20, 2007 | 12:21 PM
joelml's Avatar
yeah thanks. i would love to do the bt but that is more money than i want to spend. i have a 87 rx7 that i am also trying to "restore" as well. thanks for the fast reply. i am at work and have nothing else to do right now!
Old Jan 20, 2007 | 12:26 PM
joelml's Avatar
ORIGINAL: quattrosedan
would you have to do another ecu upgrade. right now i do have the giac program.
2001 1.8t 5 speed fwd
Old Jan 20, 2007 | 01:05 PM
NuYorka103185's Avatar
yes you need thek04 software. I got mine for only $700. You can find REAL K04's for a good price if you look hard enough. I actaully saw a post here fora company who just got a shipment from Borg Warner in about a month ago and jumped all over it. I got lucky but they are out there.
Old Jan 20, 2007 | 01:06 PM
ORIGINAL: NuYorka103185
yes you need thek04 software. I got my actual K04for only $700. You can find REAL K04's for a good price if you look hard enough. I actaully saw a post here fora company who just got a shipment from Borg Warner in about a month ago and jumped all over it. I got lucky but they are out there.
Old Jan 20, 2007 | 03:41 PM
onepoint8tee's Avatar
k04 and k03 housings are the same except for the k04 is ported and has larger compressor wheel and better journal bearings. The gpopshop k04 retains the k03 exhaust site of the compressor wheel and that is the only difference. K04 will should make most peole happy because of early spool up and and the good amount of tq you can get with the right tuning. Anything that can produce more than 250hp +all that tq, or close to it should be a good time for most people.
Old Jan 21, 2007 | 12:22 AM
ORIGINAL: onepoint8tee
My problem is that there is no such thing as enough....[:@]
01AvantQTM
Nov 7, 2010 11:10 PM
Jorgen
Mar 29, 2009 02:21 AM
JONMAH1
Jul 9, 2008 05:29 PM
OffshoreGuru
B7 Models
Jul 6, 2008 12:10 PM
garciajd
Aug 9, 2006 01:21 PM
