Power Pully Kit Question...
Old Feb 1, 2006 | 02:34 AM
StepUpProductions's Avatar
Default Power Pully Kit Question...
Does anybody use or know if the power pulley kit offered by neuspeed is worth the money and is reliable for its 5-7 HP gain?
http://www.neuspeed.com/products/pro...euro&p_id=1825
Old Feb 1, 2006 | 02:53 AM
juice88's Avatar
Default RE: Power Pully Kit Question...
well i want a pulley kit also but they say u actuallly lose power rather than gain it
Old Feb 1, 2006 | 02:59 AM
dan908's Avatar
The logic is legit on how these things work, but I would not do it if you are trying to realize a horsepower gain. Basically it is creating less work for your engine by under powering all of your components (smaller pulley ratios). That works, but it is not a noticeable horsepower gain and it is not nice for your car since you under power your Alternator, A/C, Powersteering. Again underpowering everything is not noticeable, but when your battery goes out every 4 years instead of 5, your A/C is not quite there, or your powersteering pump fails a little sooner, when you put real miles on your car (200000) you start to think was it worth 5 horsepower at the engine (nothing noticed at the wheels)?
So I checked the link, slightly different from other ones I have seen, but still the same thought, only it is all underpowered at the crank. Smaller pulley, shorter belt. Your car was engineered the way it was for a reason.
Old Feb 1, 2006 | 03:19 AM
juice88's Avatar
o
Old Feb 1, 2006 | 03:20 AM
alright thanks that definatly changed my decision on that... better to just keep that 200 and save up for something else with more significant gains... thanks
Old Feb 1, 2006 | 03:22 AM
PandaXpress's Avatar
StepUpProductions have a dual side mount intercooler kit, which one is it and maybe u should use that money and upgrade to GIAC big injectors if u havent already
toolagit2qwit
Sep 19, 2007 10:38 PM
Andyrew
Mar 27, 2007 01:32 AM
verdict
Mar 12, 2007 03:45 PM
SMoLiK
Jun 2, 2006 09:07 PM
Dudek12
May 31, 2005 10:10 PM
