Pully Noise or not??
Old Sep 15, 2007 | 11:29 PM
toolagit2qwit's Avatar
Default Pully Noise or not??
Hello- I have a '98 A6 2.6- I had my timing belt, tensioners, water pump, etc... Replaced a year ago- Also, just did a tune up (new wires, plugs and PVC hose) - My issue is I am hearing some type of rotational noise which I think is coming from the front passenger side of engine. I was originally thinking it was a valve noise but I have read that valve noises go away after the oil has warmed throughout the engine- Anyway, does anyone have any suggestions? I am hoping it is not a timing belt pulley- Also, what are my risks (keep driving) and is there a way to test or check to determine where and what is making this noise-
Note: I found a thread on "pulley noise" but am not sure if the issues are same-
Thanks in advance for your help!
Old Sep 18, 2007 | 10:46 PM
Default RE: Pully Noise or not??
Too add to this- my car sounds like diesel at idle
Old Sep 18, 2007 | 11:59 PM
auditech79's Avatar
If it sounds like a diesel at idle i would first have your oil pressure checked to make sure that is up to par.
If thats ok its probably your hydraulic cam adjuster on the passenger's side.
Old Sep 19, 2007 | 10:38 PM
Thanks auditech79- "Engine is 2.8" I am sure you knew that-
1) What causes low oil pressure (oil pick up unit, etc..)-I had a compression test back in June and it was fine-
2) If it's my hydraulic cam adjuster what is involved to fix and what should Iexpect to pay for this job- I am hoping it doesn't involve removing the timing belt
I have an appointment next Monday to get this checked and just want to know what I am looking- Also, are any of these DIY and should I be driving with those potential risks?
Abbey
Apr 11, 2008 09:43 AM
Andyrew
Mar 27, 2007 01:32 AM
verdict
Mar 12, 2007 03:45 PM
StepUpProductions
Feb 1, 2006 03:22 AM
Dudek12
May 31, 2005 10:10 PM
