Power Steering fluid replacement procedure?
Old Oct 30, 2005 | 06:33 PM
DarkHelmet's Avatar
Default Power Steering fluid replacement procedure?
Folks,
I've seen this recommended as appropriate 60-80k maint, but cannot locate a tech article or how to... any suggestions or experience doing this? Many thanks.
Old Oct 31, 2005 | 06:04 PM
Jestnomen's Avatar
6th Gear
Default RE: Power Steering fluid replacement procedure?
Underneath the power steering reservior are two hoses. Disconnect them and drain the fluid out. You'll need to go buy some new hose clamps most likely because Audi uses the ones you have to cut off. Refill the tank and drive the car for a day or two. Then repeat the procedure again. That is the easiest way to flush out the system. Make sure you only use OEM mineral fluid. YOU CAN NOT NOT NOT put regular fluid in there or you'll burn the pump out ($$$$$).
Old Nov 6, 2005 | 04:54 AM
dankhound's Avatar
Remove both hoses at reservoir. Put the hose that goes the pump in a container filled with new power steering fluid. Put the other hose in a drain bucket. Start engine. Just make sure you dont run out of clean fluid. You dont want to run the pump without fluid.
whemurad
Jan 1, 2019 02:22 PM
jlballer
Aug 16, 2008 07:00 PM
J.E.T.
Apr 14, 2008 10:55 PM
thrax982
Mar 31, 2005 10:15 PM
