problem with boost gauge
Old Mar 9, 2006 | 01:38 PM
Dunzie182's Avatar
Default problem with boost gauge
i have a chipped 99 a4qtm and decided to put a gauge in the other day...i finally got it to work but theres a few problems...
1. im idling at 8 Hg and only boosting to around 5-6 peak which i know isnt right
2. it sounds like theres boost being leaked out behind my gauge (which im assuming is the cause of #1)
anyone know whats wrong?
Old Mar 9, 2006 | 01:44 PM
aRIf's Avatar
Default RE: problem with boost gauge
you should tell whats wrong...
not enough info. where did you connect the gauge hose ?
make sure u tight everthing!!
hg should be about 20-22.
5-6 peak is normal if it is stock.
Old Mar 9, 2006 | 02:07 PM
north5995's Avatar
Yeah thats definately not right... As aRIf said, im stock at 20-22hg with peak psi at 7ish.
Old Mar 9, 2006 | 02:46 PM
onepoint8tee's Avatar
ORIGINAL: north5995
Dang.. You need a chip!
Old Mar 9, 2006 | 03:06 PM
InsaneHatter's Avatar
ORIGINAL: Dunzie182
I think this is obvious...
Pull out the gauge and make sure you clamped everything right... follow the noise...
That leak will cause low vaccum/low boost readings... Might not effect your engine as much as the gauge...
so yea.. find the noise..
Old Mar 9, 2006 | 03:09 PM
north5995's Avatar
Yeah I am booking my appointment for next week... can't wait!
Old Mar 9, 2006 | 04:04 PM
drkenan's Avatar
Uummm...are you sure the "noise" isn't the normal sound of the boost gauge? It should make a sort of metal rattling sound. Otherwise, check all your lines really well and make sure that the grommet on the firewall didn't pinch it closed.
Old Mar 9, 2006 | 04:36 PM
north5995's Avatar
Good point. Mine does have a small amount of air sound - boost running through the guage. I know though that there is no leak.
If you are chipped, it sounds like there is a leak somewhere and as drkenan said, you may have pinched the line somewhere along the way.
turboshane
Jun 19, 2010 11:09 AM
Foot12balla
Dec 30, 2008 02:33 PM
4RINGSROD
Jun 28, 2008 06:43 PM
ultrasport
Jan 6, 2007 11:47 PM
ryanmcell
Mar 1, 2006 06:35 PM
