Problem filling ATF fluid
Old Jan 9, 2007 | 02:20 PM
b_coulombe's Avatar
Default Problem filling ATF fluid
Hey Guys
I just changed the ATF filter, and I'm having some problems now with the fluid leaking out of the car. I filled it up to level. Car runs like a champion for 1 day and then I find a puddle of $30/Litre atf fluid on my driveway the next morning. WTF. Any ideas? THANKS
Old Jan 9, 2007 | 02:31 PM
techbod's Avatar
Default RE: Problem filling ATF fluid
did you replace the main gasket since you dropped the auto tranny sump to get at the filter?? chances are its not seated right or you buggered it
Old Jan 9, 2007 | 04:02 PM
onepoint8tee's Avatar
the pump doesnt get dropped when you drop the pan to change the filter. But, ya... You did change the pan gasket and tighten the drainplug right? Did you buy a new o ring for the drain plug or even lose the old one if reusing? all you have to do is get under there to see where its leaking from.
Old Jan 9, 2007 | 05:09 PM
Pson's Avatar
Tq in a star pattern...I did and it was fine for a few days then I starting seeing a little leak...when under the car and one whole side was lose and not Tq??? I was like WTF...but ReTQ them again in a star pattern...nothing has leaked after that
Old Jan 9, 2007 | 07:03 PM
b_coulombe's Avatar
Thanks all, I bet i lost the gasket or something stupid like that.
Old Jan 9, 2007 | 07:28 PM
Pson's Avatar
You don't know if you lost a big gasket while taking the filter and installing a new pan?
Old Jan 9, 2007 | 07:53 PM
ORIGINAL: Pson
hah.. Thats what i was thinking... I mean, the gasket IS bigger than your head ya know?
Old Jan 9, 2007 | 09:02 PM
truckjunky87's Avatar
Question is did he add the oil and then button it up before warming the the transmission up? Proper service is to add the fluid and then warm the transmission up to some temperature(not sure what it is but it is in the repair manual). Once it has reached the temp and while keeping it running you tighten the draing plug and then turn the car off. As the tranny heats up things expand and it will push some of the fluid out. If you don't allow it to warm up you've overfilled the tranny and it's coming out of the vent.
Old Jan 10, 2007 | 12:26 AM
Pson's Avatar
No thats not right you need to fill the tranny pan before the ATF hits 32 degrees. That is why they say use a vag-com to read the therm sensor off the tranny pan. Also the hotter it gets the less ATF he will have in the pan, but I always see people filling the tranny and turning off the car till the ATF stops leaking out the fill hole (DONT EVER DO THAT) But he didn't put a gasket it seems. He doesn't even know if he installed one? He needs to tell us what he did so we can give you a better answer.
virtualelvis
Aug 22, 2009 11:27 PM
suziebee
Feb 23, 2009 10:31 PM
GBaker
Feb 23, 2009 04:32 PM
junya
Nov 19, 2008 09:40 PM
ADubyaD
Aug 26, 2007 10:10 PM
