Problems...
Old Sep 18, 2007 | 01:16 AM
B5Bobby's Avatar
Default Problems...
i have to questions about wat my car is doing
lately i have been noticing a raddling noise (sounds like the tranny) only when im idleing in nuetral but when i put my clutch in it goes away...
when im driving every once and a while it will beep and flash an ABS and BRAKE light on the dash and its been doing it a lot lately.
i checked the brake fluid and it doesnt look low but it might need a little, it doesnt look low enough to be beeping at me though
any answers???
i hope its nothing to major considering im broke..
THANKS!!
Old Sep 18, 2007 | 01:35 AM
The Russian's Avatar
Default RE: Problems...
does it rattle in any gear while in idle? like if you are at a stop, and put it in 5th gear say and hold down the clutch, does it still rattle the same? or is it just in first gear? or only in nutral?
Old Sep 18, 2007 | 01:44 AM
B5Bobby's Avatar
its only in neutral, if i put the clutch in it goes away and comes back as soon as i let it out
Old Sep 18, 2007 | 02:16 AM
BadLuckAudi's Avatar
could just be some clutch chatter
Old Sep 18, 2007 | 02:39 AM
B5Bobby's Avatar
hopefully, its kinda loud though.
Old Sep 18, 2007 | 03:17 AM
the first audi that i fixed up had a similar problem, but it was deff the tranny... it would rattle all the way through first gear and then go awya the moment you shift to second... so if you are not getting any rattle while driving i'd say you are fine, i'd still try to get it on a lift and see if you can find anythign obvious... i know when when i worked at a mustang shop those things always came in with blown pilot bearings but i dont' know how audi set up their stuff, still kinda new to them
Old Sep 18, 2007 | 03:27 AM
B5Bobby's Avatar
yeah im new to it too, i was thinking pilot bearing too just from past experience with stick shift vehicles ive owned. but im not too educated on the audi yet
thanks for the help so far!
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
