Problems A4 02 Quaddro 3.0
Hi,
1) I have an A4 Quaddro 3.0; however it has a problem when I make a Right turn it makes noise in the rear end ( right turn only).... I was thinking either is an bad Axel or a CV join. I am very sure it is not a tire rubs because it sounds like something wrong in the bearings.
2) another problem I had is an engine light went on, and restart the battery then started the engine then engine lights went away, but weird part was the engine is seem to vibrate little bit, but the idle odomerter is acting normal; however as a engine getting warmer then the vibrating goes away.
thanks in advance.
Thy
thanks in advance.
Thy
#1 - always SEARCH 1st.
#2 - it Quattro, not "quaddro"
#3 Sounds like CV joint
#4 give it few days and see what happens. Either code will come back, or things will smooth out after 40 miles once ecu has had time to adjust everything.
Smokin Tubes
Feb 5, 2012 10:11 AM
commedecargons
Nov 9, 2005 06:43 PM
