Problems A4 02 Quaddro 3.0
Old Jul 27, 2006 | 05:50 PM
bihoang's Avatar
Default Problems A4 02 Quaddro 3.0
Hi,
1) I have an A4 Quaddro 3.0; however it has a problem when I make a Right turn it makes noise in the rear end ( right turn only).... I was thinking either is an bad Axel or a CV join. I am very sure it is not a tire rubs because it sounds like something wrong in the bearings.
2) another problem I had is an engine light went on, and restart the battery then started the engine then engine lights went away, but weird part was the engine is seem to vibrate little bit, but the idle odomerter is acting normal; however as a engine getting warmer then the vibrating goes away.
thanks in advance.
Thy
Old Jul 27, 2006 | 06:21 PM
acetrebo's Avatar
Default RE: Problems A4 02 Quaddro 3.0
#1 - always SEARCH 1st.
#2 - it Quattro, not "quaddro"
#3 Sounds like CV joint
#4 give it few days and see what happens. Either code will come back, or things will smooth out after 40 miles once ecu has had time to adjust everything.
Old Jul 27, 2006 | 07:26 PM
BadLuckAudi's Avatar
lol quaddro thats classic, but yea sounds like a cv man
Old Jul 27, 2006 | 07:35 PM
onepoint8tee's Avatar
Pretty sad when there are 3 badges, 1 on the front, 1 on the inside in front of your face, and 1 on the trunk that clearly say quaTTro.... haha.
Smokin Tubes
Feb 5, 2012 10:11 AM
redrhino
Oct 26, 2011 03:49 PM
aznmpr
Sep 29, 2009 02:32 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
