PROBLEMS WITH LIQUIDS HELP!
Old Sep 7, 2007 | 11:19 PM
  #31
wazup773's Avatar
Default RE: PROBLEMS WITH LIQUIDS HELP!
ya the autos dont have dip sticks i looked for it i felt dumb loll but i will shure get if flushed tommrow then rush to auto zone check the codes and then str8 to the mechnic to get it fixed hopefully tommrow
Old Sep 7, 2007 | 11:21 PM
  #32
lboudreau's Avatar
Good stuff. Let us know how it goes!
Old Sep 8, 2007 | 02:15 PM
  #33
CRAZYHAWK's Avatar
I assume you have a tip. You'll need a VAG-COM or an Audi code reader
to read and reset error codes.
Old Sep 9, 2007 | 08:35 AM
  #34
david9999's Avatar
Honestly, I think you need to take the car to a mechanic that deals with Audi's and VW. No offence meant, but you don't seem to have the basic understanding of engine maintenance and repair. Your safest bet is to let someone who knows what they are doing find out what is wrong and fix it.
In the meantime, you can buy a Haynes manual for 15 dollars, and learn the basics of car maintenance.
Old Sep 11, 2007 | 06:02 PM
  #35
wazup773's Avatar
So guys so far i havent driven my car till today i took it to auto zone and got the codes the code was p0600 and troubleshooting dint show up fo audi it just gave me a meanin which says the pcm has determined that the malfunction exists in the serial communication link between the pcm and other modules in the system.. and for vw it says
definition
eplanation open or short circut condition
Old Sep 11, 2007 | 06:31 PM
  #36
lboudreau's Avatar
pcm? Interesting. Sound like the error is related to that code scanners link to your car. But thats just a guess.
Serial Comm. Link (Data Bus) Message Missing
^ that is the message from the Bently manual
Actually... That kind of sounds like somthing is currupt somwhere in the ECU.
Old Sep 11, 2007 | 06:39 PM
  #37
wazup773's Avatar
Ya i think its the ecu where is the ecu u located and what is it?
Old Sep 11, 2007 | 06:56 PM
  #38
lboudreau's Avatar
ECU (Engine Control Unit)is basically the "brain" of your car. if the "brain" is dead, or half dead, then the car won't work properly. But I'm just guessing. There could be somthing wrong with the ECu to prevent it from being able to give you the codes you need. PCM is what I really don't get. Someone else on here might know. Its located on the drivers side behind the firewall sealed in a water proof container (has an umbrella on it)
Old Sep 11, 2007 | 06:58 PM
  #39
wazup773's Avatar
kool thanx man i dont no what is wrong with it hopefully some 1 nos
Old Sep 11, 2007 | 07:15 PM
  #40
onepoint8tee's Avatar
Try diconnecting your battery for 30 mins and hooking it back up. It should reset the ecu. Then try to get scanned again. If that doesnt work, somehow, try to find an ecu from a different2.8 w/same engine(dont know if you have 12v or 30v)/tranny and see if that changes anything. Hopefuly someone will have better advice than that, but it does sound like the problem could be the ecu.
