Problems Shifting
Old Jan 15, 2008 | 11:26 PM
abomb55076's Avatar
Default Problems Shifting
Hello, I have a 1998 Audi a4 1.8t Quattro. What happens is I am driving around 35 MPH and the transmission willfeel like itsstrugglingor laggin. It feels like its not going into the nextgear.If I punch the throttle the carfeels like it kicks in and thecar accelerates fine. But if I lay off and drive leisurely the transmission will continue to do this.Please help! THanks!
Old Jan 16, 2008 | 01:52 AM
1SIKA4's Avatar
Default RE: Problems Shifting
automatic eh? id say take it to the shop, sounds like something is slipping maybe or somethings not catching when it needs to
Old Jan 16, 2008 | 03:06 PM
redsox12's Avatar
Sounds like the transmissions slipping
Old Jan 16, 2008 | 03:08 PM
AteUrV8's Avatar
so does it eventually shift??? depending on how fast your accelerating im sure you know it will shift at different points. has it been doing this ever since you had the car or is this something that your just now obviously realizing?
Old May 21, 2009 | 12:54 AM
freelancer_samir's Avatar
Default Problems shifting
I'll tell you the exact reason for shifting problem which is the common problem of Audi A4 1995-2002 (excluding B5 models in 2002). I suppose you see on the panel all the gearbox possitions redlighted on. Like, when the gear position is on (D)rive, on the panel it should show only D, but it shows all the positions on. The problem is shifter which costs in my country around 100 USD. But I'll tell you how to fix it without any change of details. You go to diagnostic center, they plug the comp to your car and reset the transmission error, that's it! But after that you should never shift the gear to 3rd and 2nd position manually, or if your car is a tiptronic one, don't use it, put only on D when you drive, it will do good. freelancer_samir@yahoo.com in case you wish to contact me.
teamdaraptor
Nov 11, 2008 02:05 PM
nukemdead
Jun 12, 2006 05:01 AM
1BADS4
Jan 8, 2006 05:41 AM
a6cruiser
May 30, 2005 02:50 AM
skidude
Aug 31, 2004 04:37 PM
