profec b NEED HELP!
Old Dec 4, 2007 | 08:28 PM
chaos92287's Avatar
Default RE: profec b NEED HELP!
yeah its just a connection to make things easier, 1 white and 1 green on both ends of the clip so i can just cut both and solder the wires, right?
there's no way im stripping the tiny wire tho, i can barely get the stripper even in the position to strip it cause of the other wire and its so small
Bogie's Avatar
ORIGINAL: cincyTT
try this... http://www.alamomotorsports.com/gred...EC_B_SPEC2.pdf
THe valve unit (bottom left of top pic) shouldnt have a T in it. On line goes where the n75 is and then the wire on the back goes to the controller.
The line with the filter goes from the controller to the fpr buy itself.
Then you just need a ground and 12v source
Maybe he had this T here for using the boost gage while also running the PROFEC.
Old Dec 4, 2007 | 08:37 PM
chaos92287's Avatar
ORIGINAL: Bogie
ORIGINAL: cincyTT
nah cincy was talking about the T coming out of the IN line of the control motor. for some reason he connected that hose to the hose going from the FPR and intake mani to the controller unit instead of where the n75 is, and then used 1 of the connections from the 3 way joint to go to a boost gauge
Old Dec 4, 2007 | 08:48 PM
Bogie's Avatar
Oh, thought he was referring to the T where you have '...FPR?' labeled. That's where I put my T for my boost gage line.
Have fun with that, looks complicated ata first glance. Hopeyou get it working right.
Old Dec 5, 2007 | 05:01 AM
chaos92287's Avatar
yeah it looked complicated at first but when i started thinkin bout everythin, it makes sense. im just gona redo all the wiring how Greddy shows it, screw this kids ghetto install
nyone8t
Jun 1, 2009 06:18 PM
dr_zoidberg
Jun 25, 2008 02:42 PM
onesickassfasta4
Jun 3, 2008 11:14 AM
Bondga
9
Oct 23, 2007 11:48 PM
Noobinator
Jun 6, 2007 08:28 PM
