Put a little green coolant in... (didn't know)
Old Aug 21, 2006 | 05:37 AM
alpherjo's Avatar
Default Put a little green coolant in... (didn't know)
Hi all,
I recently bought a 2004 A4. The coolant level was a little low so I added about one fifth of a gallon of Prestone 50/50. It says that this anti-freeze is 'All Models' and that it can be added to 'Any Color Coolant" on the container.
Is this a problem? Should I empty it all out and replace the coolant? I'm confused now about the 'green' coolant and the 'purple' coolant. I searched some past threads and some said not to mix, but some said this coolant should be ok. I'm taking the car in in 3 weeks for it's 35k tuneup. Can I wait until then?
Thanks for any help!
Old Aug 21, 2006 | 07:21 AM
socal_A4's Avatar
Default RE: Put a little green coolant in... (didn't know)
What type of car...? If turbo, I highly reccomend draining and filling it up with the proper pink coolant.... bottem line if you have a turbo... and care about your car... you will drain it and fill it with the proper coolant..
Old Aug 21, 2006 | 10:10 AM
wood_e's Avatar
I've run the green stuff with no issues. I just change it yearly.
Old Aug 21, 2006 | 12:29 PM
CRAZYHAWK's Avatar
The antifreeze that is good for all cars is yellow.
Old Aug 21, 2006 | 12:51 PM
smokeU's Avatar
i'm pretty sure our cars need the G12 pink stuff. That's just what I heard.
Old Aug 21, 2006 | 03:41 PM
CRAZYHAWK's Avatar
smokeU, G12 pink is OEM. You can switch to Universal yellow by first flushing the system.
Old Aug 21, 2006 | 03:43 PM
Jeff's Avatar
Zombie Defense Force
ORIGINAL: smokeU
yup
Old Aug 21, 2006 | 06:21 PM
Session101's Avatar
don't mix and match, you should be running dex-cool
Old Aug 21, 2006 | 07:47 PM
wood_e's Avatar
I've heard dex cool corrodes more easily
Jack_Tauson_Sr
Aug 1, 2015 05:46 PM
djjuice
Dec 9, 2010 10:08 PM
randomloginname
Apr 23, 2007 02:33 AM
pliddy
Sep 4, 2004 06:40 AM
