Question about power outlet/cigarette Lighter
Old Apr 5, 2013 | 04:20 PM
jnp89's Avatar
Default Question about power outlet/cigarette Lighter
I'm a girl with little knowledge of cars, so bare with me if I'm not using the correct 'car terms' lol
I have an 1998 Audi Quattro A4 and I have a universal phone charger for my car that I can't use because the cigarette lighter / power outlet inside the car seems to be too large to fit it (the 'plug' for the charger sits very loosely inside of it)
I've been using the same cord for a while in different cars and have never had a problem with it fitting into a cars electrical outlet. I also tried looking around for a larger sized charger but all the universal ones seem to be the same size. I tried my sisters car charger as well just to see (also a universal charger, but a different kind) and it also did not fit.
It's not broken as far as I can tell...I have one in the front and one in the back. I've tried both, and both are too large for the adapter.
Does any one have any advice or is there a charger for my phone that is specifically sized for car?
Thanks so much!
Old Apr 7, 2013 | 05:41 PM
Expplucky's Avatar
wrap the outside of the charger in foil thick enough to make it a tight fit it will work but make sure none of it is poking out other wise it may shock you while its plugged in, also i wouldnt leave it plugged in while your not in the car. sadly audi was a dick about making thes outlets! you may be able to crimp the input a little bit, but that would require removing the center console. FOIL will work tho!
(i have to do the same thing with my car)
djspawn
Aug 26, 2011 02:41 PM
puji
Feb 14, 2010 12:27 PM
lespaul2510
May 21, 2009 10:55 PM
jschuster123
Apr 27, 2008 08:03 PM
viento_a6
Sep 19, 2006 05:06 PM
