Rainwater collecting in battery bay and leaking into footwell
Old Nov 5, 2011 | 12:25 PM
Nellyuk's Avatar
Default Rainwater collecting in battery bay and leaking into footwell
Hi everyone
For a while now I have been having problems with rainwater leaking into the passenger footwell. What sees to happen is the rainwater that runs down the windscreen collects in a compartment in the engine bay which houses the battery and the zircon assembly, when going round a sharp corner you can hear the water sloshing about in there, it also effects the airflow through the outlets in the car. I am assuming if the water level gets high enough it overspills and ends up leaking into the passenger footwell soaking the carpet.
Does anyone know if theres meant to be a drainage hole or something that I can check to see if it's blocked? I don't want to start drilling holes in a galvanised body shell encouraging rust to start.
Model: 1999 A4 Avant 1.9 TDI (110) SE
Many thanks
Old Aug 4, 2013 | 11:50 PM
Kenny Gerard's Avatar
Im having a very similar problem. I forgot to check out that area of my 98 a4 2.8 and it was all rusted out. Definitely would like to find an awnser to this too. I was thinking about plugging the holes in the screen but that would heat the engine more I suppose..
Old Aug 10, 2013 | 09:35 PM
Expplucky's Avatar
check that all your drain grommets arent clogged. ive read other posts where it was as simple as that.
adamellisuk
Jul 16, 2014 06:50 AM
moneyfresh
Oct 13, 2013 10:18 PM
bayfield
Jul 11, 2011 10:50 AM
macaroon
Jan 26, 2009 05:18 AM
Bryceaudi
Jul 31, 2007 03:42 AM
