re-wiring back speakers
Old Oct 21, 2007 | 11:25 AM
Mya4T's Avatar
Default re-wiring back speakers
alrght so i got a new headunit formy car. and i know you have to rewire the back to speakers cause of the stock amp. went to the back speakers and there is about 10 wires cominf from each speaker. which to wires do i need to cut so i can re wir it. and which on is negative and postive
Old Oct 21, 2007 | 11:55 AM
fumoazul99's Avatar
Default RE: re-wiring back speakers
https://www.audiforums.com/m_622462/mpage_2/key_/tm.htm
theres a lot of good info on that thread....
but the easiest way that i figured out was to buy new rear speakers.... that way u dont have to worry about what wires to cut and so on..
Good Luck!
Old Oct 21, 2007 | 05:41 PM
hollisterrobsta's Avatar
Had SAME problem as you. Do you have bose or non-bose? Well it doesnt matter really cause your talking back speakers. The back speakers are fed through an AMP mounted on the back right speaker I believe. Basically your going to have to cut those wire from the harness (or buy a new harness from Crutchfield) and wire the amp inputs to the deck outputs for the rears, I believe there are two 'hot wire' one is purple and the other is green. There are two ground wires which are grey. Not for sure on the colors though ill have to look. The amp is a line-level system, so you don't need to use RCAs, as I orginally did, which causes really low level for the back speakers vs. the front speakers. So bacically just look at the samp, look to see which wires are the same color back there as up front by your deck, those are your amp input wires, from there you just gotta connect them to your decks r/l rear channel outputs. Don't forget the remote wire either, or the amp wont turn on.
Old Oct 21, 2007 | 05:45 PM
Limbs's Avatar
[sm=headbang.gif]Search
gaw, im grumpy today.
hen000
Feb 12, 2011 03:02 PM
jowie4
B7 Models
Mar 27, 2009 08:30 AM
Mya4T
Oct 23, 2007 06:15 PM
DenimTT
Jun 16, 2006 01:01 PM
grapejuice
Jan 12, 2006 05:48 PM
