Is it really worth it??
Old Nov 16, 2007 | 03:28 PM
aRIf's Avatar
Default RE: Is it really worth it??
make your mind first then spend money on it. if you get it chipped now, they you have to spend again to get right chip for your bt setup.
Old Nov 16, 2007 | 04:17 PM
Papachristou's Avatar
i found a k04 with 12k on it.. guy wants $300.. i think im going to do it to keep me pacified a bit longer..
Old Nov 16, 2007 | 06:06 PM
turbo kraut's Avatar
Tech Guru
ORIGINAL: Papachristou
a ko4 will show you no gains since you are already +1...... i think ko4 on the new 1.8 only gives you up to the 225ish range and since you have that........ why would you do it
maybe since you are a b6 someone else might tell me i am wrong, but on the b5's that is the case
Old Nov 16, 2007 | 06:07 PM
Tech Guru
ORIGINAL: turbo kraut
a ko4 will show you no gains since you are already +1(and that is just for the turbo, not to mention another say 700 for programming)...... i think ko4 on the new 1.8 only gives you up to the 225ish range and since you have that........ why would you do it
Old Nov 17, 2007 | 12:02 PM
Search4Unknown's Avatar
If you got the cash.. go for it
[align=left] [/align]
Old Nov 17, 2007 | 12:27 PM
chaos92287's Avatar
ORIGINAL: jduplooy
what can I say, you guys have convinced me, I am going to look into a GIAC chip, If I got BT can I get my software upgraded pretty easily? And is it neccessary to install a boost guage or just novelty?
Thanks guys
if you go BT later, you will have to get a new chip but companies offer discounts if you stay with them. If you really are planning on going BT, get revo, they will most likely be who you get your BT software from
a k04 is POINTLESS in a b6 and near pointless in a b5 w/ a k03s. since you already have the bigger injector file, upgrading to a k04 would net you ~5hp. not really worth the 800 your gona spend on just the k04 and software.
Old Nov 17, 2007 | 02:00 PM
ocadam's Avatar
I would only do that if your Ko3 went bad.
MarkR540
Oct 31, 2010 09:17 PM
moeron7
Apr 16, 2008 12:59 AM
bryans 86
Feb 18, 2008 10:54 AM
