Rear Brake pad replacement
Old Jan 27, 2007 | 03:56 AM
a3square's Avatar
Member
Default Rear Brake pad replacement
Help! I've got a '02 A4 quattro. I've got the caliper of and the new pads in place but can't get the piston backed into the caliper. I did my fronts with no problem.Do I have a frozen caliper or am I missing something or some step?
Old Jan 27, 2007 | 04:20 AM
tommygn's Avatar
Default RE: Rear Brake pad replacement
you need a caliper tool, rent one from autozone, or buy one if ur gonna be doing your brakes again.
Old Jan 27, 2007 | 06:56 AM
mtr005's Avatar
you usually can get them back in with a large flat blade and a heap of pressure
Old Jan 27, 2007 | 01:39 PM
CRAZYHAWK's Avatar
The rear pistons should be screwed in. Use the special tool or a needle nose pliers.
Old Jan 28, 2007 | 05:47 AM
ScAndal's Avatar
I'm going to be doing my front brakes in a few weeks. Is there a how-to anywhere for replacing breaks on 02 1.8T?
ScAndal
flippu10
Oct 2, 2010 12:02 PM
patchelect
Jun 28, 2009 03:35 PM
motorwerks1
Feb 21, 2009 02:03 PM
blackdjone
Feb 26, 2007 12:28 AM
modset
Jan 13, 2007 03:37 AM
