Rear caliper question
Old Apr 3, 2006 | 07:41 PM
BadMajik's Avatar
Default Rear caliper question
I changed my rear pads yesterday and when finished i noticed that my passenger side caliper moves in and out, with some but minimal force, whereas the driver side will not move at all. Furthermore i somtimes notice a kind of clicking or clunking noise when i first press my brake pedal. Is this a problem with the caliper or is somthing mabey loose? I checked all my bolts and they are all tight. Thanks for any help.
Old Apr 4, 2006 | 12:00 PM
BadMajik's Avatar
Default RE: Rear caliper question
Bump any ideas?
Old Apr 4, 2006 | 04:27 PM
Yuikio's Avatar
How did you retract the pistons? You might have popped it out of the seal...is there brake fluid leaking or anything?
Old Apr 5, 2006 | 01:38 AM
BadMajik's Avatar
I screwed them back in like you are supposed to, and i guess i should have clarified this but the caliper moves back and forth when it is on the car. The drivers side does not budge but the passenger side slides back and forth like if the caliper was engauging when the brakes are off and the car is just sitting.
Old Apr 5, 2006 | 01:42 AM
KevinBNH's Avatar
check the caliper slide pins. they are probably worn
audivalley
Jul 26, 2012 01:19 PM
audivalley
Jul 24, 2012 09:30 PM
CRuby
Oct 14, 2011 04:42 PM
to3o
Sep 9, 2008 08:42 PM
noot74
Jan 20, 2007 07:43 PM
