Rear Speakers
Ok, well I would just run new wires to the rear speakers to be safe. It's not bad, just start them at the cd player, pull off the panel underneath the steering wheel (3 screws? can't remember), the panel next to the hood popper (2 screws), then just lift up those long panels that run the length of the front and rear door openings (just pull up gently), pull off your rear set, flip your rear backs down, then, if you can manage it, hook them up to the rear speakers without taking off that rear deck panel... If for some reason you need to pull off the rear deck panel, just remember to unhook the rear brake light. Run both wires on the same side to save time... Or you could take it to a shop and it would prob be an hour, hour and a half of labor, maybe more if they take you for a ride...
no this is insane . i have plug in the back of the radio without the rear speakers hooked up instead they are cut and attached to rc cables coming out of the deck WTF . i tried to hook up the cut cables , but nothing. i will test a speaker on those wires coming out of the deck. and i will test the speakers {rear} by attaching a 9 volt battery to them so they (pop) if they work
AmadiAudiA4
Aug 15, 2008 11:31 PM
