rear sway q...especially for moderator
Old Apr 16, 2005 | 06:13 PM
CheckMyVitals's Avatar
Default RE: rear sway q...especially for moderator
and sexy
Old Apr 16, 2005 | 06:21 PM
CRAZYHAWK's Avatar
A stiffer front anti-sway bar will increase understeer.
Old Apr 16, 2005 | 06:24 PM
David_K's Avatar
depends where it is. if its in the front it helps the initial turn in but increases understeer. if it s in the back it increases oversteer.
Old Apr 16, 2005 | 06:31 PM
CRAZYHAWK's Avatar
[quote]ORIGINAL: awol
Well putting the sport front on should reduce body roll with a small loss in understeer.
David K ,I was responding to this quote.
Old Apr 16, 2005 | 06:34 PM
David_K's Avatar
i wasnt saying that you were wrong
Old Apr 16, 2005 | 06:53 PM
awol's Avatar
take a look at my new post regarding this issue...as I originally wrote...and forgot that I wrote...the front did greatly reduce body roll with an unoticable change in understeer from 0mph to 60 mph...have not test high speed.
Old Apr 16, 2005 | 07:57 PM
BFlan2001's Avatar
ORIGINAL: awol
.....Well putting the sport front on should reduce body roll with a small loss in understeer.....
putting on just the front sway bar will increase your understeer at any speed...not just above 60mph, where did you get that info?
Old Apr 16, 2005 | 08:42 PM
  #18
CRAZYHAWK's Avatar
Thank you bentframe. Understeer can be reduced by replacing the front shock absorbers with firmer 50/50 jounce/rebound ones.
Old Apr 16, 2005 | 08:45 PM
  #19
David_K's Avatar
exactly. do you have the sport suspension? if so you could switch to the non-sport front sway bar. also you could give your rear tires more positive toe
Old Apr 17, 2005 | 03:09 AM
  #20
awol's Avatar
Default to bentframe
My info comes from my recorded slomon times before and after the install
again a physics issue...there is a nominal loss in understeer under 60mph. I say 60 because a) that is what i tested at and b) the equations of yaw change over that until and quantify with acceleration.
96A4Owner
Mar 20, 2008 01:50 PM
germantech
Dec 24, 2007 02:29 AM
B5luver
Dec 18, 2007 12:42 AM
The Russian
Sep 24, 2007 08:48 PM
audihere
Jul 19, 2005 04:26 AM
