rear view mirror leakage
Old Nov 11, 2005 | 03:28 PM
TeenAudi's Avatar
Default rear view mirror leakage
My rearview mirror has an internal leak that has turned the majority of the mirror a tinted brown. It"s a little annoying and now the auto dim does not work. I assume this is the auto dim material that has leaked? I also assume I have to get a new mirror...any idea on where to find a replacement?
Old Nov 11, 2005 | 04:41 PM
toaster's Avatar
Default RE: rear view mirror leakage
"auto-dim material?"
not quite sure what you mean by that. also not quite sure of your problem.
could you explain a little bit more about what's actually going on?
Old Nov 11, 2005 | 04:48 PM
PandaXpress's Avatar
u can go to a junk/salvage yard or look search here www.car-parts.com for a used mirror
ORIGINAL: toaster
the chemical or liquid inside the mirror that darkens th3e mirror
auto dimming mirrors are alrite but i dont think they really work
if u look at your rear view mirror you will see a lil hole in the centerish that has a light sensor
when theres is a lot of light you will notice the mirrors will actually dim
if someone hight beems you at night the mirrors will dim and it kinda prevents glar a lil
Old Nov 11, 2005 | 06:58 PM
dankhound's Avatar
The mirror uses an lcd(liquid crystal display) to control light reflection in the mirror. Thats probably what you see leaking.
Old Nov 11, 2005 | 07:31 PM
Jestnomen's Avatar
6th Gear
It's a fairly common problem. To remove the mirror, cut out two pieces of coat hanger approx 8" long. Bend the last 1/2" over 90 degrees to creat hooks. Insert one of the hooks on each side of the mirror. Now pull the mirror out of the ball socket. It may take a little force. Once the mirror comes out there should be a few wires to disconnect. ECS Tuning sells some autodim replacement mirrors too. Shouln't take more than 10 minutes to replace.
soundguy
Aug 3, 2015 05:05 PM
Alvaro Izquierdo
Apr 1, 2009 11:38 PM
IzeBerg
Nov 29, 2008 11:21 PM
ccomengee86
Oct 2, 2007 09:27 AM
mdre83
Jan 9, 2007 09:59 AM
