remote?
Old Mar 24, 2007 | 12:26 AM
kopez03's Avatar
Default remote?
i was just woundering if anybody knew the correct replacement batteries for the remote? because i called three dealerships and they all told me different numbers i bought the cr1620! are those the right ones adn do i have to reprogram the remote once i put the knew ones in?
the reason i am replaceing the batterys is when i bought the car 5-6 months ago it work alittle bit but i had to be real close to get it to work!with in the last couple days it just stopped working? does your remotes work from a ways away or do i have something else wrong andthat is whymy remote wont work?
thank you
Old Mar 24, 2007 | 12:51 AM
BaconBait's Avatar
Default RE: remote?
Try the DIY section. I'm pretty sure there's a guide in there on how to program the key in there. I did both of mine. Only takes a couple minutes.
Old Mar 24, 2007 | 02:15 AM
L.E.O.'s Avatar
Default RE: remote?
you can open up the key and look at the batteries themselves to see what kind they are, its in the manual.
Old Mar 24, 2007 | 01:25 PM
andrewbb89's Avatar
Default RE: remote?
ya i also have to be within 10 feet of my car for the remote to work. hopefully its similar to your problem and is just the batteery
Old Mar 24, 2007 | 01:30 PM
new2me's Avatar
Default RE: remote?
These cars dont get a very far range with the remote. There is a DIY on the zine or 1 of the other Audi sites that tells you how to increase the distance by relocating the antenna from the fender to the rear baffle board.
Old Mar 24, 2007 | 03:20 PM
Trey25's Avatar
Default RE: remote?
Yes you will have to reprogram the remote, not difficult. Not quite sure which batteries work. For some reason the range on the b5 is very short, mine is about 20'.
Old Mar 24, 2007 | 05:31 PM
Pablo_Ottawa's Avatar
Default RE: remote?
Open your remote and find out. For my 02 A4, it's a CR 2032. Take your old batt out and bring it to a drug store and just match it up. Here in Canada a local Shopper's Drug Mart usually has these types of Batteries. Hope this helps
Old Mar 24, 2007 | 05:32 PM
Default RE: remote?
By the way, it's not the battery. The remote is just a P.O.S.
Old Mar 24, 2007 | 08:49 PM
kopez03's Avatar
Default RE: remote?
yeah i changed the batteries and you are right they are a big pos!!!!! it works but not far i have to almost put it right in front of the windshield to get it to work!!!
AudiGirl92
B7 Models
Aug 31, 2013 08:28 AM
MartinCieslak1
Dec 11, 2009 02:30 PM
krshrk
B8 Models
Sep 18, 2009 07:08 PM
Albee G
Mar 9, 2008 08:21 AM
marcink99
Jan 26, 2008 10:09 PM
