removing pin striping?
Old Jan 21, 2006 | 02:24 AM
Simone's Avatar
Default removing pin striping?
i want to remove my pin striping because it looks gay.
whats the best way to do it? i figured heat it up with hair dryer and slowly peel it off, clean in up with goo gone...
anyone else have experiance doing this?
Old Jan 21, 2006 | 03:27 AM
tip5's Avatar
Default RE: removing pin striping?
Your method should work.
Old Jan 21, 2006 | 03:30 AM
AML 225's Avatar
I know people have done this before and I'm pretty sure their method was very similar to what you suggested.
Old Jan 21, 2006 | 03:49 PM
sandman's Avatar
your good to go if theres not a clearcoat over the pin stripe.
Old Jan 21, 2006 | 04:03 PM
Jestnomen's Avatar
6th Gear
3M also makes some stuff to remove them.
Old Jan 21, 2006 | 04:18 PM
SKiTZo's Avatar
I detail cars for a living.. you are pretty much ok to use a heat gun and your fingernail. It's time consuming but least damaing to your car. Any of the chemicals available will affect the other layers of paint so I wouldn't recommend them.
Old Jan 22, 2006 | 05:30 PM
semperwasted's Avatar
is this the same method used for debadging?
Old Jan 22, 2006 | 05:49 PM
Kellya4's Avatar
This also works great.http://store.autotoolexpress.com/pireto.html
Old Jan 23, 2006 | 06:02 AM
SKiTZo's Avatar
Best way to debadge a car is to use teeth floss and some non abrasive adhesive remover. Works like a charm.
Old Jan 23, 2006 | 12:21 PM
kaklexicon's Avatar
I took the stripes off of my car. In cold weather just use the hair dryer as you go and you can peel them off one section at a time (fender, doors, etc...). Once they are warmed up they come off like butter.
rb12
Aug 3, 2010 12:34 AM
ad91
Mar 4, 2009 03:02 PM
FormulaCAR
Mar 18, 2008 11:11 AM
johnstef
Dec 18, 2007 01:57 PM
clconversion
Jan 10, 2005 12:21 AM
